Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains
Page 4 of 4 <1234
Kot
Nasher wrote:
Anyone have any idea about drains at the front as per my posts above?
I just came across this.
https://www.fullfatrr.com/gallery/albums/u...0LEAKS.pdf
It shows external rain water leakage paths and there are holes/drainage channels at the front end of the roof frame/panel, these drain externally so not such an issue. But still like all drain holes (Tailgate etc) need to be checked and cleared periodically like we do Whistle .
The roof opening panel frame incorporates drain holes in each front corner allowing water to drain via the A pillars and each rear corner allowing water to drain via the roof panel channels.[/i] 2018 SE SDV8 4.4 Byron Blue
Post #708168 3rd Jan 2025 11:04am
Gremlin500
@Kot:
Very good, that last bit regarding the tailgate grommet is very interesting, I have had the odd drip after jetwashing, but never just with rain. FFRR tailgates do commonly go out of alignment Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708171 3rd Jan 2025 11:11am
Nasher
Kot that's fantastic, many thanks. Thumbs Up
Post #708178 3rd Jan 2025 11:54am
supershuttle
Nasher wrote:
Geoff. I need to clarify that I'm not asking if it's a big issue numbers wise, it appears that it's affecting too many otherwise good L405s.
But for me personally I don't think it's a big issue if caught early, because I can put it right myself.
If you are not capable of sorting it yourself and it has been allowed to get really bad then it is a big issue.
Don't worry I will be inspecting my drains to make sure it doest happen to me. Very Happy Geoff
Post #708181 3rd Jan 2025 12:44pm
Nasher
supershuttle wrote:
Don't worry I will be inspecting my drains to make sure it doesn't happen to me
Post #708185 3rd Jan 2025 1:11pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Had a go at this recently - bought a flexible drain brush from Amazon, but without wanting to force it, it stops about 18” down each drain tube, presumably where they turn down the C-pillar. Both sides were draining, but the nearside slightly more slowly - might have a go with compressed air rather than cut the arch liners.
What was worrying was finding the beginnings of rust at the entry of both drains - I’ll treat it, but was surprised.
Post #708191 3rd Jan 2025 3:03pm
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
I’m guessing issues leading from blocked drains isn’t covered by Extended Warranty?
Post #708232 4th Jan 2025 2:14am
Page 4 of 4 <1234
