Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1230 |
I just came across this. https://www.fullfatrr.com/gallery/albums/u...0LEAKS.pdf It shows external rain water leakage paths and there are holes/drainage channels at the front end of the roof frame/panel, these drain externally so not such an issue. But still like all drain holes (Tailgate etc) need to be checked and cleared periodically like we do . The roof opening panel frame incorporates drain holes in each front corner allowing water to drain via the A pillars and each rear corner allowing water to drain via the roof panel channels.[/i] 2018 SE SDV8 4.4 Byron Blue |
3rd Jan 2025 10:04am |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 |
Kot that's fantastic, many thanks. |
3rd Jan 2025 10:54am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
Don't worry I will be inspecting my drains to make sure it doest happen to me. Geoff |
3rd Jan 2025 11:44am |
3rd Jan 2025 12:11pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2574 |
Had a go at this recently - bought a flexible drain brush from Amazon, but without wanting to force it, it stops about 18” down each drain tube, presumably where they turn down the C-pillar. Both sides were draining, but the nearside slightly more slowly - might have a go with compressed air rather than cut the arch liners.
3rd Jan 2025 2:03pm |
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 59 |
I’m guessing issues leading from blocked drains isn’t covered by Extended Warranty? |
4th Jan 2025 1:14am |
