Home > Maintenance & Mods (L405) > Rear Anti Roll Bar Links - MY17 SDV8 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 |
This one works
29th Dec 2024 5:18pm |
Bagus Member Since: 14 Apr 2014 Location: London Posts: 200 |
Part numbers in this link https://www.fullfatrr.com/forum/post671902.html 2016 5.0 Loire Blue
30th Dec 2024 9:15pm |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 204 |
Thanks both, I was able to verify the numbers on JLR classic. Haven't used that site in a while and finding L405 stuff on there wasn't straightforward as there used to be no navigation but you could locate via PN.
3rd Jan 2025 8:39pm |
CJames525 Member Since: 09 Mar 2024 Location: CT Posts: 4 |
With the dynamic response system, how hard is it to change out the rear/any DIY’s or write ups? Parts are coming in Monday to do mine, as I have a horrific creak like an old mattress when driving with the slightest bit of articulation. Hoping it is the bushings, but being I have a 2017 figured they were due anyway and a good place to start.
11th Jan 2025 2:26am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 |
Rear bushes are easy, fronts are a PITA as the support bracket has to come off and the bolts for these may strip the threads on refitting.
11th Jan 2025 8:40am |
My indie is doing mine, one thing I do know from the procedure is to clean up the surface for the D bushes very well as this can cause creaking (your creak is likely from excessive movement tho!) |
11th Jan 2025 11:15am |
