![]() | Home > Technical (L322) > 2012 L322 Tuning Adaptive Dynamics (Magneride) |
jeremy156 Member Since: 05 Nov 2024 Location: Southampton Posts: 6 ![]() ![]() |
That doesn't sound like a great idea. Remember it's a solenoid in the damper, that is an inductive load (coil) not a resistive one; therefore it's current that matters, not voltage.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 498 ![]() ![]() |
It's got nothing to do with voltage. Changing the voltage will likely destroy your Adaptive Dynamics Module (ADM).
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 119 ![]() ![]() ![]() |
Hello All,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
My April 2012 build has the updated cables. I've unplugged the cable retaining fixings on both sides to ensure that the cables can move freely. |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 75 ![]() ![]() ![]() |
As does mine, built at the end of February 2012, and the cables look identical to yours. 2012 TDV8 Westminster in the New Forest
How much EXTERNAL movement is there at the electrical contact in the strut top? It can't be much.
The same change in angle as the wheels. |
Thanks Graeme |
The plate under the nut to which the vibration damper attaches needs to be set at about the correct angle with the steering straight ahead before the nut is tightened, otherwise the wiring can be strained on full lock. |
