Home > Technical (L322) > L322 2010 battery voltage
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
Please could someone advice if the battery voltage when running is looking correct? New battery and alternator done 6months ago. Keeping getting gearbox fault message on dash and going into safe mode.
Voltage when running 13.64v
Post #708120 2nd Jan 2025 4:17pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I would have thought nearer 14.4 with engine running. May be lower if run for a while and battery fully charged. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #708127 2nd Jan 2025 6:03pm
Apps
Yes I keep seeing post on her of people saying it should be around 14.4v. I'm having some intermittent electrical issues one being gearbox fault. Maybe could be due to low voltage issue
Post #708128 2nd Jan 2025 6:05pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Mine, 09 Facelife 3.6, new alternator 4 years ago runs at 14.4 V, with regards to the Gearbox error, I assume you have changed the oil and filter and the Mechatronic plug, is there an error number?
Started the beast this morning 11.9V and it was all fine, back on charge tonight though..
Will
Post #708136 2nd Jan 2025 8:00pm
Apps
The error code for the gearbox is this
Post #708142 2nd Jan 2025 8:19pm
