![]() | Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 ![]() |
Thanks Drf.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1460 ![]() ![]() ![]() |
You will see if they are blocked for sure and if they have corrosion around holes, best policy is pour a cup of water in there and see if it appears out behind the rear wheels or if it just holds. Only way to tell in reality is pull headlining but they won't want you doing that. if it has a cloth headliner you will see staining around grab handle area's if its leaking. Mine has leather so harder to see |
Thanks DrF
I would think that would be a good shout |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1657 ![]() ![]() ![]() |
There’s already an onboard moisture meter: -you open the rear door slightly, and water gushes out! |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
OMG we will then need an un-gloat emoji ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
here's a pic showing the drain pipes,
with the trams for the mechanics i can see why you need the drain pipes but the fixed doesnt have these so no water to drain away... unfortunately i cant find any diagrams to support my theory.. ... - .- -. Y. O. L. O. . |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 900 ![]() ![]() ![]() |
I would have thought the fixed glass roof is bonded into place much like the windscreen and won’t require drains, happy to be corrected however |
i concur J... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3887 ![]() ![]() ![]() |
It would make sense and be the same as everyone else with a glass roof (not opening sunroof) if it was just sealed in like the windscreen or indeed the rearmost windows (load space side windows) but then again JLR and common sense in the same sentence |
It's just occurred to me, are there only two drain pipes, one each side in the middle?
I just posted this link in the other sunroof drains thread, but repeating it here in case it’s useful:
I'm a little surprised nobody has commented on this, surely I'm missing something obvious and water draining to the front of the opening has somewhere to go? |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 60 ![]() ![]() |
I have just been out to test mine and poured water into the front either side with the sunroof open. Water drains to both front wheel archs so they must be there somewhere. It may be hidden behind the very front glass and drain to the outside of the vehicle via the side windscreen channels?. I cannot find any images or mention of front pipes? |
