Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 44 |
Thanks Drf.
17th Dec 2024 2:37pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1403 |
You will see if they are blocked for sure and if they have corrosion around holes, best policy is pour a cup of water in there and see if it appears out behind the rear wheels or if it just holds. Only way to tell in reality is pull headlining but they won't want you doing that. if it has a cloth headliner you will see staining around grab handle area's if its leaking. Mine has leather so harder to see |
17th Dec 2024 2:51pm |
Thanks DrF
17th Dec 2024 3:00pm |
I would think that would be a good shout |
17th Dec 2024 3:05pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1474 |
There’s already an onboard moisture meter: -you open the rear door slightly, and water gushes out! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
17th Dec 2024 4:20pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1216 |
OMG we will then need an un-gloat emoji 2018 SE SDV8 4.4 Byron Blue |
17th Dec 2024 6:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
here's a pic showing the drain pipes,
17th Dec 2024 8:33pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 866 |
I would have thought the fixed glass roof is bonded into place much like the windscreen and won’t require drains, happy to be corrected however Jonathan
17th Dec 2024 8:37pm |
i concur J... ... - .- -.
17th Dec 2024 8:39pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
It would make sense and be the same as everyone else with a glass roof (not opening sunroof) if it was just sealed in like the windscreen or indeed the rearmost windows (load space side windows) but then again JLR and common sense in the same sentence Geoff |
18th Dec 2024 8:31am |
