![]() | Home > General > Write off due to rear bumper, what to do ! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
I have a 2009 Vogue ( 2010 MY ) with 145,000 miles on the clock, someone went into the back off me and the insurance company have said its beyond economical repair ( CAT N ) as it needs a new bumper. To be honest the bumper isn't that bad and probably just needs a bit of readjusting. The car is perfectly drivable and still in good condition, I have serviced it myself for the last 5 years and it had a full history prior to that from an independent.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Experience of this - not with an RR but with a BMW 3 series
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8450 ![]() ![]() ![]() |
Just remember what you are looking at is not a "bumper" it's a very thin plastic cover, the strong bit is the crash bar bolted to the rear of the monocoque. It could be badly damaged as well as the monocoque so you need to check this out, you can see some of it from inside the spare wheel well but damage can be subtle and difficult to identify...
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1797 ![]() ![]() |
Thanks for the replies :
This is the damage:
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1634 ![]() ![]() ![]() |
Better the Devil you know, as they say. Keep it!
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 243 ![]() ![]() |
So basically their offer is, £4,237 plus you can keep the car which will be Cat N and your NCD is unaffected?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
damage looks superficial...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7882 ![]() ![]() ![]() |
No expert here, but isn’t there an inspection thing you can have done after it’s repaired that will remove the CAT whatever status? Or is that only for more severe categories?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
No, was looking at that the other day. If it’s a structural repair then you can get it assessed for raodworthiness and put back on the road, but the cat always stsys with the car once it’s been written off. Even on cat N and cat S cars. 👍🏻
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1435 ![]() ![]() |
That looks like the dark plastic trim will reseat into the painted section and you could leave it at that.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Can’t speak for all tow bar formats but mine certainly retains the crash bar and I would guess most do as the crash bar is the main structural element from the hit in the rear. Having seen your photo it’s a no brainer, it’s a 30 minute job to get the rear bumper off and looking at the damage I’d be confident you could save the bumper, maybe the plastic trim might need replacing. I’m actually surprised it’s a write off and maybe says more about the state of the network of repairers than the cost of the parts, I bet you could sort all that for less than £400 at a motivated body shop. J |
If it's Cat N you just need to re-MOT it to put it back on the road...
