Home > Maintenance & Mods (L405) > L405 key fobs not operating today - Happy Christmas |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1503 |
I’d say your system voltage is too low, nothing more.
25th Dec 2024 1:12pm |
LiKuid Member Since: 05 Dec 2024 Location: Athens Posts: 14 |
Interesting… main or aux battery? |
25th Dec 2024 7:42pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 135 |
I did perform a hard reset by disconnecting the main battery for 10 minutes which didn't resolve the fob issue. So, I'll put the battery on charge tomorrow. The main battery is only 18 months old. I replaced the original battery because it wasn't holding a proper charge when the secondary aux battery was fine on charge.
25th Dec 2024 10:17pm |
AFAIK the second battery is only for Stop/Start, (I don’t actually have one myself).
25th Dec 2024 11:42pm |
Charging the main battery for 5 hours didn't make any difference.
26th Dec 2024 6:00pm |
I bought the main battery from Halford's 2 years ago and it has a 5 year warranty so I dropped in there after a 40 mile run that had the battery showing 78% of capacity charge and a voltage of 12.17V. They put their battery tester on and it said good battery, just in need of a charge. Halford's will only exchange if the voltage is below 10V.
28th Dec 2024 4:46pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
Sorry to hijack this thread slightly, but where is the auxiliary battery?
28th Dec 2024 6:37pm |
The secondary battery is behind the right hand card. Lift from the bottom first then pull away from the tailgate side. It is held on by 6 press studs. |
28th Dec 2024 6:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35372 |
If you don't see the aux battery then you will have a capacitor instead.. ... - .- -.
28th Dec 2024 7:31pm |
Thanks Stan. I will check tomorrow. 2015 Range Rover Autobiography 4.4 SDV8 |
28th Dec 2024 7:57pm |
I found it. Crikey, I was expecting a typical auxiliary battery, not one big enough to start a medium-sized family car!
29th Dec 2024 4:39pm |
The meltdown continues.
30th Dec 2024 10:01pm |
So, when my main starter battery was on the way out, I didn't get any messages, but weird things started happening. The upper rear tailgate would open, but wouldn't close and just beeped at me. The other thing that started happening was my easy entry/exit wasn't working (which got really annoying with the seat all the way down and the steering wheel up).
30th Dec 2024 10:08pm |
I fitted a new Halfords main battery 2 years ago which is on a 5 year replacement guarantee. I took the car to Halfords and their tester says the battery is good, even though I do have my doubts. I did get them to agree that if a garage confirms that the battery is at fault then they would replace it.
31st Dec 2024 10:33am |
