![]() | Home > Maintenance & Mods (L405) > L405 key fobs not operating today - Happy Christmas |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 145 ![]() ![]() ![]() |
I charged using a ctek that took the charge over 80% of capacity which didn't make any difference. After the 5 hour charge and a 45 mile drive 2 days later Halfords said it was around 70% on the CCA. The strange thing with the battery is low voltage, typically 12.1V to 12.3V.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
What’s the voltage with the engine running ? Should be circa 14.4 is less than that probably an alternator issue 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Sounds like the battery and nothing more complex than that, to me. Remember cold weather can quickly kill weak batteries.
The car charging voltage on a running engine is 14.8V so there is nothing wrong with the alternator. |
Update on this:
enzo19352 Member Since: 10 Mar 2025 Location: devon Posts: 2 ![]() ![]() |
Hi, did you get this issue sorted sorry to ask ? I just brought a range rover a few days ago with this issue |
It got kind of sorted. I left the battery on charge for 72hrs and that raised the capacity to over 70% and the voltage to 12.7V. Then the Gremlins were beaten and have yet to return. |
Hi thank you for your reply. by any chance did this stop your phone connecting and the audio tab being blurred out? |
No, I never had that issue. I would have noticed if it had as I Bluetooth the phone for music. |
