Chaps,
I would suggest then that there exists more than one potential source for possible leaks from the knurled basin fitting. Mine appears to leak not from the water sensor connection but from the drain outlet. See my thread posted in August :
https://www.fullfatrr.com/forum/topic71055.html
Initially this was caused by the failure of the viton washer which had clearly sustained significant perishing giving rise to a fuel leak amounting to a near torrent. Subsequent trials of replacement washers, genuine and otherwise, have provided a measure of relief, but sadly not amounting to a complete resolution.
Crusty - With this in mind, I look forward to reading your summary of the outcome following fitting of replacement parts as per your discussion with Mr. Tee.
Good luck.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
