Home > Technical (L460) > 22" Spare wheel gubbins
AndyS
My car came without a full size 22" spare so I've bought one which means it will never ever get used. Rolling with laughter
I don't know what parts I need to secure it.
If anyone has a spare fitted it would be really helpful if you could let me know what is required for both safe stowage and if there's a lifter strap like the L405 used to have.
Thanks in advance.
AS Current fleet:
2020 McLaren 600LT Spider
2020 Mercedes C300 Cabriolet
2023 L460 PHEV 440 SE
1992 Lotus Esprit turbo
2019 Alpine A110 (French rubbish now gone)
Post #706614 11th Dec 2024 3:18pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
This is what it looks like and yes there is a lifting strap letters not necessarily in the right order
Post #707129 17th Dec 2024 1:47pm
Bill
You can buy all the gear needed as spare parts. Mine was like yours, but they wanted £300.00 for the bits. Mainly carpet. The tyre should be fixed down so it’s doesn’t move around .
I used the screw fitting to hold the tyre in place from my trade in & regret my spare tyre doesn’t have a carpet to lie in. I took the lifter strap as well, but honestly I’m incapable of pulling those tyres out now, so it’s a call out anyway. I would expect you can buy the screw in spindle on its own.
Mines a 23 inch wheel so it’s v snug! Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #707141 17th Dec 2024 4:07pm
AndyS
Thanks for the responses, I’ll definitely get the long bolt that holds the wheel down and lifting strap. Is there a bottle or scissor jack, I guess stowed within the wheel barrel?
Lastly, do you jack the car up on the deployable side step end frames? Current fleet:
Post #707317 20th Dec 2024 9:35pm
Dixy
Scissor jack in top right corner, would only use in an absolute emergency and on solid level ground. letters not necessarily in the right order
Post #707456 22nd Dec 2024 6:21pm
