Home > Technical (L322) > Drive shaft popped out - Drivers side |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
It occurred when you changed the air strut, its quite common to happen. |
12th Dec 2024 8:57am |
MP3C Member Since: 10 Sep 2024 Location: Corby Posts: 6 |
Update:
15th Dec 2024 2:38pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 51 |
That looks as though the shaft hasn’t been fully fully home, otherwise it would have sheared much further down the shaft/ spline or possibly not sheared at all. |
15th Dec 2024 3:01pm |
I think its all related to my front strut change. I think I had accidentally unseated it when doing the swap and then as you said, has been unseated, all power right on the end and has just failed where the recess has been cut for the clip. |
15th Dec 2024 3:17pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 71 |
I had mine pop out after not installing it properly following a strut change. No damage however! I thought it was going to be difficult to do but it turned out to be quite simple.
16th Dec 2024 4:32pm |
