Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains
Page 1 of 4 1234>
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Don't be like me and take an impromptu shower at the first tight corner of the morning. Pop off those trims and check the drains at least yearly.
Both of mine were blocked, attacked with a long plastic cable tie as weapon of choice. Follow up with a few jugs of hot water. No corrosion noted though, which is something!
Post #706914 15th Dec 2024 12:08pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
which trims do you mean? First time FFRR owner
Post #706917 15th Dec 2024 12:24pm
caymanblack
Yes as Arch asked , how do you get to them ? thx. overfinch modified
Post #706930 15th Dec 2024 2:03pm
unsolicited
The trims run from front to rear either side of the sunroof glass and can be levered out with a plastic trim removal tool. (This is where you can fit the optional roof rails)
There are quite a few youtube videos such as:
https://youtu.be/eaFG3Orqj7E
That poor soul had corrosion, but the video shows where the drain holes are.
Actually this video is probably even better
https://youtu.be/w_jzPeBof00
Post #706935 15th Dec 2024 2:37pm
Arch Stanton
nice one, thanks mate, I shall get mine off now seeing as the weather is good here First time FFRR owner
Post #706954 15th Dec 2024 4:31pm
supershuttle
Mine will have to wait for a good day, getting it detailed next week, should be fun. Geoff
Post #706989 15th Dec 2024 9:32pm
caymanblack
Thank you unsolicited a couple of good videos there.
I will try the preventive measures he used. overfinch modified
Post #707032 16th Dec 2024 2:27pm
oh the comfort of me having a fixed panoramic roof.. [gloat] Mr. Green ... - .- -.
Post #707033 16th Dec 2024 2:35pm
Gremlin500
Me too! Mr. Green
Stan, can you add a new [gloat] emoji, for our use, please?
“Less is more” Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #707035 16th Dec 2024 2:44pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’ve never opened mine, too scared 😱
Post #707079 16th Dec 2024 11:08pm
Arch Stanton
I like mine and open it regularly but I’d not miss it much in the next one. First time FFRR owner
Post #707081 16th Dec 2024 11:13pm
unsolicited
Neither did I. The drains still block though so need checking Sad
Post #707100 17th Dec 2024 8:37am
supershuttle
I'm a bit like AS, I use it a lot (during summer in my case) but thats because its there, if it wasn't I wouldn't really miss it. But I will check the drains as I didn't even know there was a problem. Geoff
Post #707111 17th Dec 2024 9:48am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I am still confused here, surely the drains still exist if you have a fixed pano roof, the only time they wouldn't exist is if you had no sunroof at all? If you look at the parts for the roof the sunroof channel for fixed pano roof still has drain points???
Post #707132 17th Dec 2024 2:35pm
Nasher
If I was viewing a car with an opening roof, how easy would it be to inspect the state of the drains?
Obviously I can see from the videos where the drains are, but what can be done in a normal viewing of a potential purchase at a dealers without asking to strip the car too much?
I’m assuming a hand on the carpets at the bottom of the B and C posts will reveal any serious water ingress along with an inspection of the headlining.
Is there anywhere to get a hand in to see if it’s wet, assuming it’s been raining recently?
I have a small 6mm diameter head Endoscope with lighting that connects to my phone, is there anywhere to shove that in to see if the drains have broken away from the tray.
I’m not actually that bothered unless there is serious water ingress actually inside the car that could have already done some damage, as I’m more than capable of removing the sunroof, dropping the headlining and drilling out the rusted originals to replace with bonded in plastic or brass ones made up in my lathe.
Actually it could be a really good way to pay less for a car I could prove there is an issue with.
Post #707133 17th Dec 2024 2:59pm
Page 1 of 4 1234>
