Home > Maintenance & Mods (L405) > Diesel fuel leak - driver side RR L405
pec2960dk
Denmark 2016 Range Rover SVAutobiography SDV8 Carpathian Grey
Hi,
I have a diesel leak driver side (LHD) on my RR.
It is quite a bit, looks like it comes out center or near the driver's door.
I have it to a diagnostic with a mechanic, who removed the protection shield beneath the engine and it was quite wet from diesel. I needed to take some parts out to further investigate - but i did want the car ending up at the shop and be presented with a huge invoice...
I have noticed that below the drivers door fuel is dripping - could be travelling from below the engine... Or it has travelled from driver side to the engine shield, as the car is parked slightly sloped at our driveway.
I really need some help it figuring out what the problem is. Anyone had similar problems?
Post #706907 15th Dec 2024 11:20am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Possibly leaking from the bottom of the fuel filter and then running down the bulkhead and back. Worth a quick look at the filter to see if its wet. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #706923 15th Dec 2024 12:40pm
pec2960dk
Thank you for your help. Will look into that tomorrow ,🙏
Post #706931 15th Dec 2024 2:09pm
Kot
its not from the fuel burner heater is it? 2018 SE SDV8 4.4 Byron Blue
Post #706936 15th Dec 2024 2:41pm
pec2960dk
Thank you. Could be. But I thought that is located passenger side ?
The car is slow to heat up inside and when using the pre-heater its never get really warm. So it could be related. I will check that as well! Thanks a lot.
Post #706937 15th Dec 2024 2:48pm
Mcdaddyjester
Hi
I had a 2011 RRS which had a diesel leak in a similar location. It was the diesel breather/return pipes that return diesel back to the tank.
There were numerous connections underneath the car that worked lose over time.
Post #706948 15th Dec 2024 4:04pm
pec2960dk
Thank you for your input.
I had that on my list as well.
What would be the easiest way to check this without a lift ?
Thank you in advance.
Post #706999 15th Dec 2024 10:54pm
Mcdaddyjester
I put the suspension in the highest setting and crawled under. It was kind of obviously after a few mins with a torch. Biggest issue was the number of joints. I reconnected three but others just popped off. I think I should have replaced the entire system as I think I probably had a blockage somewhere. Part ex'd the car in the end for a l405.
Post #707059 16th Dec 2024 8:23pm
pec2960dk
Thanks 👍. I will give it a go.
I also bought an endoscope camera attached to my phone, this will allow additional visibility.
Post #707066 16th Dec 2024 8:42pm
Kot
Shocked
Brave man Whistle 2018 SE SDV8 4.4 Byron Blue
Post #707090 17th Dec 2024 12:55am
