Home > Technical (L405) > Amber light lean when cornering
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys had amber light last night saying lean when cornering to left scanned with IID and got the following any ideas?
CHCMB-Chassis Control
C1057-14 (2C) Rear axle - Pressure regulating valve - General electrical failure - circuit short to ground or open Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #648679 20th Nov 2022 9:10pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
any update? I get the same when cornering hard to the left....only the left. Goes away if you turn off/on.....but will come back again after letting vehicle sit for a few hours then cornering left again. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #651372 21st Dec 2022 3:45pm
TxWild
United States
Suspension Fault Question
Did you ever get this problem resolved? I have the same warning "Suspension Fault-Vehicle Lean when Cornering" message on my dashboard screen. I used an Autel scanner and received these codes (see pic). Does anyone know if this is the REAR AIR SUSPENSION VALVE BLOCK that needs replacing or is it something else? Any help would be greatly appreciated. My ACE reservoir is good and I don’t see any leaks or otherwise.
Post #706819 14th Dec 2024 5:48am
horse86
LR said they needed to replace valve block etc. I decided to live with it. RR rides great and very smooth. Only on cold starts I’ll get the light “thump” on the first sweeping left turn that triggers the light. Then rides as normal. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #706820 14th Dec 2024 5:56am
TxWild
United States
Thanks, I appreciate the update. I agree, and with the holidays around the corner, I don’t feel like sinking in $500. Mine also rides great and other than the error popping up when I start it, I can’t really tell a difference. It raises and lowers fine and the only feature that’s affected is not being able to change the custom driving modes. I was also concerned about whether or not I’m potentially causing more damage by continuing to drive it, but sounds like as long as I go easy on her, I should be good.
Post #706821 14th Dec 2024 6:24am
horse86
I can still use the rotary knob and change the terrain settings…that’s odd that you can’t. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #706822 14th Dec 2024 6:50am
TxWild
United States
It says terrain settings are unavailable. You think it’s something other than the pressure relief valve? A friend of mine mentioned the ACE system but just a theory.
Post #706823 14th Dec 2024 7:12am
jaysta10k
Hi my warning light was only coming on intermittent at first and once I cleared it with IID tool it would stay away for a while but now it’s constantly on and I can’t clear it but car drives completely fine I think this issue is definitely related to a sensor or bad earth maybe. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #706840 14th Dec 2024 12:33pm
horse86
The ace system includes the valve block…it’s one and the same.
I can still use all my terrain options. Even if/when the error pops up. It doesn’t effect my ride so pointless to throw money at it. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #706882 14th Dec 2024 9:09pm
fisha
So the error reads as though it's the ace system valve block. Pressure is generated by the pump at the engine, and there are valves in the ACE valve block which will release that pressure into the hydraulic units on the anti-roll bars.
As I understand it, each of the front and rear units is a loop circuit, and the valves can send the fluid in either direction around the loop to counter leans to either side. This may likely be why you're only seeing it happen on one side of cornering.
When I did my ACE pipe replacement, the area around the valve block was filthy, and the connectors and top of the valve block were caked in mud. It might be worth getting access to the valve block and cleaning out that whole area ( take the sill tray off basically ) and making sure the connectors are all clean and working well. It could be as simple as some moisture in there. V8 or else ...
Post #706941 15th Dec 2024 3:05pm
