Home > Technical (L405) > Amber light lean when cornering |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
any update? I get the same when cornering hard to the left....only the left. Goes away if you turn off/on.....but will come back again after letting vehicle sit for a few hours then cornering left again. 2014 FF Autobiography 5.0 SC
21st Dec 2022 2:45pm |
TxWild Member Since: 14 Dec 2024 Location: Texas Posts: 3 |
Did you ever get this problem resolved? I have the same warning "Suspension Fault-Vehicle Lean when Cornering" message on my dashboard screen. I used an Autel scanner and received these codes (see pic). Does anyone know if this is the REAR AIR SUSPENSION VALVE BLOCK that needs replacing or is it something else? Any help would be greatly appreciated. My ACE reservoir is good and I don’t see any leaks or otherwise. |
14th Dec 2024 4:48am |
LR said they needed to replace valve block etc. I decided to live with it. RR rides great and very smooth. Only on cold starts I’ll get the light “thump” on the first sweeping left turn that triggers the light. Then rides as normal. 2014 FF Autobiography 5.0 SC
14th Dec 2024 4:56am |
Thanks, I appreciate the update. I agree, and with the holidays around the corner, I don’t feel like sinking in $500. Mine also rides great and other than the error popping up when I start it, I can’t really tell a difference. It raises and lowers fine and the only feature that’s affected is not being able to change the custom driving modes. I was also concerned about whether or not I’m potentially causing more damage by continuing to drive it, but sounds like as long as I go easy on her, I should be good. |
14th Dec 2024 5:24am |
I can still use the rotary knob and change the terrain settings…that’s odd that you can’t. 2014 FF Autobiography 5.0 SC
14th Dec 2024 5:50am |
It says terrain settings are unavailable. You think it’s something other than the pressure relief valve? A friend of mine mentioned the ACE system but just a theory. |
14th Dec 2024 6:12am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Hi my warning light was only coming on intermittent at first and once I cleared it with IID tool it would stay away for a while but now it’s constantly on and I can’t clear it but car drives completely fine I think this issue is definitely related to a sensor or bad earth maybe. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
14th Dec 2024 11:33am |
The ace system includes the valve block…it’s one and the same. I can still use all my terrain options. Even if/when the error pops up. It doesn’t effect my ride so pointless to throw money at it. 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
14th Dec 2024 8:09pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1405 |
So the error reads as though it's the ace system valve block. Pressure is generated by the pump at the engine, and there are valves in the ACE valve block which will release that pressure into the hydraulic units on the anti-roll bars.
15th Dec 2024 2:05pm |
