Home > General (L405) > L405 clocked mileage
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
A ab lwb fifty 21 plate, less than 30k miles and 4.4sdv8, where is is please if its only a fraction more than my17.
I looked for 18mths and didn't find any that ticked the above boxes you have done well with finding 15. Cheers
James
Post #706697 12th Dec 2024 1:58pm
Rob99
Not knowiing what your exact spec was, it was just an example from a quick search that there are 15 LWB available at the moment on AT with varying age, mileage and price.
You're not going to get a Fifty edition LWB with a 4.4SDV8 as they didn't make them. They'd switched to the D350 by then. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #706711 12th Dec 2024 4:20pm
Scouse Exile
Hi James,
Has the dealer talked about accepting the car back? Given you bought it as a distance sale, you have much stronger consumer rights if you want to go down the road of rejecting it.
Outside of this I think a good starting point would be to have the car fully independently inspected so you can rule out any possibility of it having been an accident damaged car that’s been put right off the book. Given the mileage discrepancy it’s worth knowing exactly what you’ve got before going any further.
Sounds like you like the car and it’s what you want, so long as it stacks up legally, mechanically and financially then maybe there’s a route through this that you’ll be happy with.
Jon
Post #706734 12th Dec 2024 9:38pm
D3Jon
JST wrote:
Clocking is 54k less 31k.
Mot and services tie in. So possibly done first 3 years.
If it helps with your decisioning in any way... For me, the question of when the first service was carried out would be a massive factor in whether I would personally keep this particular vehicle. That's before discussing any warranty repairs / financial compensation for the mileage discrepancy from the seller.
The question is therefore; how old was the vehicle when it had its first service? Also, what was the recorded mileage at that service?
If it was at 3 years old, then (given the mileage has been tampered with) I'd have serious concerns for the well-being of the engine over the longer term of ownership. Obviously guessing here, but as an example, it may have actually done 39K miles and not the 15K or so possibly recorded at that first service! Shocked
SDV8's are tough old motor's, but failures aren't unheard of. They require fresh oil every year to keep carbon deposits down and the rotating bits in good fettle.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #706765 13th Dec 2024 11:02am
JST
Scouse Exile wrote:
Hi James,
Jon
Dealer is having think. I have had a jlr inspection of the vehicle completed. Asked them to cover all work currently.needed plus gone me a figure for mileage allowance. Difference is circa £5k on used price mileage difference. Cheers
James
Post #706959 15th Dec 2024 4:06pm
JST
Jon
Yep first service also.concern, currently tieing in some datamon that front. Cheers
James
Post #706960 15th Dec 2024 4:07pm
D3Jon
LR service history is available online for later models (2013 on), all you need is the VIN number.
I'm sure you know this, but here's the link just in case:
https://osh.landrover.com/
2014 Disco 4 HSE
Post #706997 15th Dec 2024 9:49pm
JST
cheers Cheers
James
Post #707072 16th Dec 2024 9:28pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Invest in a Car Verticals check, that should give a history of the mileage etc and also be able to tell you the MOT history.
It sounds to me like you've possibly, but unlikely bought a ringer, i.e. the car could be a clone / stolen with a new identity of a written off car, something like that, or history tampered with to hide something or it could just be a genuine error with the paperwork / ECU replaced at some time. Does the VIN in the front screen window and the engine number match the paperwork and the GAP IID tool and LR records.
Personally sounds like something dodgy here, but it's not a massive amount of money, if your happy stick with it, but you may have some issues when it comes time to sell. But then it gives you time to figure out what's happened.
Rozzers may come a knocking though if it's a ringer that really belongs to someone else.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #707080 16th Dec 2024 10:08pm
