Home > Maintenance & Mods (L405) > Transmission sump shield
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Hi guys
Went to do transmission oil change and filter ,just spent the last hour trying to get these two bolt’s undone (see photos).all that’s happening is there are spinning can’t get to the nut inside …anyone had this issue and if so what did you use to undo them
Post #706608 11th Dec 2024 1:21pm
cass
An angle grinder.
Post #706615 11th Dec 2024 2:24pm
will308f
yea i think that is going to be the only way as i can’t get a spanner in there to hold the nut ,better go and get new bolts/nuts
Post #706617 11th Dec 2024 2:30pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
The clips corrode through but I have managed to get two to come off using an impact. The weight of the shield pulled down a bit did create enough drag to enable the nut to turn slower than the impact drive, unwinding after a few minutes. A far easier approach than grinding.
Post #706633 11th Dec 2024 5:30pm
will308f
yea did use an impact in the end but the bolt if free however the nut on the inside also turns that’s my issue i can’t get anything in to stop it which is very annoying if i had a spanner that i could get in there dam frustrating
Post #706635 11th Dec 2024 5:40pm
