Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 |
Ran the ECU update/flash to version CH42-14C204-RTC - cycled the car a half dozen times and ran it to temp - no fault codes came up and did not go back into limp mode - yet live data still shows discrepancies - how can bank 1 and bank 2 be so out and it not throw up a fault code?
4th Dec 2024 5:30pm |
Last thing to test will be the wiring harness from the camshaft sensors right through to the ECU... while I have check, re-check and where needed fixed broken or badly repaired wiring to Bank 2.... I need to check the Solenoid-Camshaft profile switching-bank 2 cables to ECM... each camshaft sensor on bank 2 inlet and outlet share the same ground and voltage reference cables and with the P0345 and P0390 I am wondering if it might be one of these.... fact that it has intermittently worked could be down to a bad ground or short somewhere.... will test and maybe just run a complete new wire to each sensor and bypass the harness to eliminate as much as I can....failing that can't see it being anything other then an actual timing chain issue!!!!!!
6th Dec 2024 12:29pm |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 337 |
Following this with great interest. What a huge amount of work. But what skill you seem to possess. 2017 4.4 SDV8 Autobiography in black
6th Dec 2024 3:23pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3137 |
I'd be interested to know if your chains were done using genuine LR parts or one of the cheap Chinese kits that you can buy. I read online that the cheap kits don't last 5 minutes which could possibly explain some of the issues you are experiencing. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
8th Dec 2024 12:20am |
🚗 Diagnostic Journey: The Saga of Bank 2 Camshaft Sensors 🛠️
10th Dec 2024 10:00am |
Finally getting around to finishing up some interior updates—replaced the old broken start/stop switch, and it’s made such a difference! Looks so much cleaner and feels great to have it working properly again.
10th Dec 2024 10:06am |
Top work!
10th Dec 2024 10:46am |
🚗 Range Rover Project: Everything Done So Far 🛠️
10th Dec 2024 11:14am |
Thanks David....
10th Dec 2024 11:16am |
I know these rear screens are not even HD let alone 4k....but nice to have the Fire TV wired into the rear AV.... Amazon, Netflix, and Apple TV is a lot more pleasing to the kids than BBC News (the only TV channel I seem to be able to receive) and my early 2000's DVD collection of Friends and Csi......
13th Dec 2024 5:02pm |
I have never replaced brakes before; even though I have been working on my own cars for years, I kind of always thoughts that brakes were a thing to leave to the specialists... however; anyone contemplating saving some money and doing your brakes yourself, I would highly recommend it - I was amazed at how straight forward to was, I always was a little scared of out...
16th Dec 2024 5:02pm |
Other than a couple of snagging issues the Copart rescue is pretty much complete now.... I won the car at Copart on 25th September - two and a half months from pretty much a wreck to what will be a wonderful daily driver for me for a good few years ahead.....Do I regret it? Put simply no; while I could have bought one for a lot less than it has cost me to sort this one; like I had before when I saved my 2011 L322 4.4 TDV8, you can't really put a price on that feeling of accomplishment from taking a car from what was a dead wreck, back to life........and when that re-born wreck has a Supercharged 5.0 V8; how can you not just smile ear to ear while your wife shouts at you from he passenger seat to slow down............ thanks for all the comments and help from various other members... really appreciated !
16th Dec 2024 5:27pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 184 |
Quite the transformation, it has been a very interesting thread to follow, I'm officially impressed.. |
16th Dec 2024 6:41pm |
That looks like it’s scrubbed up lovely in your last picture.
16th Dec 2024 9:03pm |
