Home > Maintenance & Mods (L322) > TDV8 Aux belts and Tensioners |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Does it squeal all the time or just for a few mins after a cold start? 2012 TDV8 Vogue (L322) |
5th Dec 2024 3:33pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 |
I replaced all mine along with a new waterpump and an alternator while it was all apart. All Genuine. It started to squeak only a few months later when the weather was cold.
5th Dec 2024 4:57pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 185 |
Like Kevinp, I renewed the pulleys and tensioner with genuine, a Denso alternator was also installed at the same time. I didn't think to do the waterpump at the time, maybe I should have but the RR had only done 58K miles so should be fine. |
5th Dec 2024 5:52pm |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 153 |
It only squeals for a few minutes after starting, once warmed up it runs silent. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
5th Dec 2024 9:02pm |
Genuine LR belts and tensioners £496
5th Dec 2024 9:10pm |
It can go on for years like that and could just be the tensioner weakening or some oil or antifreeze contamination on the belt. Also replace the AC compressor as well as the alternator and water pump as these are prone to failure. 2012 TDV8 Vogue (L322) |
5th Dec 2024 10:10pm |
I should have typed air con pump not condenser.
6th Dec 2024 12:45am |
I’ve never heard of one breaking. The pulleys and tensioners will give you more noise than a few mins at cold start and the state of the tensioner is observable by how the belt is running on it. 2012 TDV8 Vogue (L322) |
6th Dec 2024 7:01am |
Thanks, I will keep an eye on it for now as everything works and it goes silent after a few minutes.
6th Dec 2024 9:38am |
Mine is a bit 'chirpy' for a few mins now the mornings are cold due to condensation and rubber loosing compliance and grip at lower temps esp as the smallest pulley is the alternator which will also have the highest load first thing. 2012 TDV8 Vogue (L322) |
6th Dec 2024 9:54am |
