![]() | Home > Technical (L405) > Ctek charger in P400e |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 796 ![]() ![]() ![]() |
Yes, there is a regular battery under the foam insert beneath the boot floor.
chicb Member Since: 27 Nov 2019 Location: Dundee Posts: 85 ![]() ![]() ![]() |
Thanks for that. |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 215 ![]() ![]() ![]() |
Which comfort connecter will you fit?
The posts under the bonnet are not proper threads, so getting a good connection is quite hard. What I did is get 2 off 7-9mm jubilee clips, (link below), then strip back the cable, wind the cable a couple of times through the clips, fit to posts then clamp up.
Great idea, be great if you can share the photos as I have been pondering a way for a while |
Pics of front of car, connector hidden, connector ready to be connected to Ctek, jubilee clip attached to neg post. (waiting on delivery of clip to attach to positive post) Pics in my gallery
That's awesome thank you. I was tempted to try the 12v outlet one, but unsure how I feel about leaving a small gap on the door seal in winter.
