Home > Maintenance & Mods (L405) > L405 Brakes
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
L405 Brakes
Hi, Guys
I have been pricing up new disc and pads for my car and went for OEM Duckworth's quote is £903
JGS4X4 for Drilled and vented green stuff pads and service kit wear sensor £296
I can't understand why so much difference in price?
( found out Duckworth's quoted for a caliper as well) So take off £ 334 + Vat still a big difference. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #703877 6th Nov 2024 11:30am
Gremlin500
OEM vs aftermarket, always the same, you pay for the name like all branded stuff. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #703881 6th Nov 2024 12:06pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
Have you tried Brembo from CarParts4Less?
The discs are squally cheap from them and Brembo pads are cheaper from LRParts
Post #703914 6th Nov 2024 8:11pm
Tinman
thanks for that, I will check them out. 2017 SDV8 4.4 silicon silver AB
Post #703928 6th Nov 2024 10:14pm
Gremlin500
I bought these 2 years ago, front AND rear for £550, genuine Brembo pads and drilled/vented discs.
They have been totally fine, no issues whatsoever. I am a qualified mechanical engineer working in the brakes industry for more than 30 years, I have no affiliation with the advertiser, other than as a satisfied customer:
https://www.ebay.co.uk/itm/264868412222?mk...media=COPY
IMHO, there is a lot of bullsh*t about OEM this & that by armchair internet experts, but there are equally some great quality aftermarket parts available, the problem is sorting the wheat from the chaff.
Much of the OEM stuff is made in various countries in Asia these days where QA can be patchy, and parts often no better quality than aftermarket at best. Caveat emptor. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #703931 6th Nov 2024 11:32pm
LT
I’ve been using Brembo pads and discs (front and rear) and can’t fault them. One advantage over the LR parts is that the Brembo disc centres (bells) do not rust.
I always shop around as online prices vary considerably.
ETA- I always avoid drilled/slotted discs as I find them a magnet for small stones when driving off road.
Post #703971 7th Nov 2024 2:03pm
Tinman
Thanks for all your input guy's Thumbs Up 2017 SDV8 4.4 silicon silver AB
Post #703975 7th Nov 2024 2:31pm
JamboM3
OE pricing works differently and is an entirely different business model, hence the price gap.
Land Rover do not make the braking parts, they outsource this. The OE pads are usually Textar or Jurid, which are widely available in the aftermarket for the same (well, might not be 100% the same as some specs might be changed from the service part specified from LR)
The discs I am not sure on, from memory when I replaced the ones on my L322 with genuine they had no markings on them to determine the supplier but ironically were competitively priced vs. aftermarket.
I found the right Textar pads on eBay, from a bulk trade seller. £48 for the front set and have been absolutely perfect since fitting. Think LR quote was around £432 for essentially the same thing.
Discs are not a complex thing, so most aftermarket applications will be fine.
Post #705977 3rd Dec 2024 10:57am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Just fitted genuine Brembo discs front and rear. £140 for the front pair and £132 for the rear from CarParts4Less (also got Brembo brake pads). I also got £30 discount as the whole order cam to over £300.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #706009 3rd Dec 2024 2:06pm
Gremlin500
Just so everyone is aware, there are a LOT of fake Brembo brake pads around, so don’t buy from unknown sources. If the price is fantastic, the pads probably won’t be. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706015 3rd Dec 2024 2:37pm
caymanblack
lol, yes Gremlin i fear IGP has a set of chinese Brembos Rolling with laughter overfinch modified
Post #706021 3rd Dec 2024 3:16pm
E500
I’ve used AUTODOC for Brembo discs and pads for a couple of my other cars and they’ve been OK, if very slow on delivery.
Plenty of horror stories about AUTODOC though so do your research.
Post #706047 3rd Dec 2024 9:16pm
IGP
@Caymanblack
Nope genuine Brembo boxes came with all the right seals and my mechanic who fitted them confirmed they were genuine.
Post #706070 4th Dec 2024 9:10am
