Home > Technical (L322) > FBH not working, advice welcomed! |
FalconFlyer Member Since: 14 Nov 2021 Location: Crowthorne Posts: 4 |
Bump. Some advice would be gratefully received! |
1st Dec 2024 6:27pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 900 |
I'm don't know what that code relates to but try again with your gap tool prime it and try to run it I put an air line in my intake to force it to run and it eventually did and worked fine there after.
1st Dec 2024 7:22pm |
Thanks. Sadly the gap tool just gives error E3 for both priming and operating the FBH.
2nd Dec 2024 7:51am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 687 |
I know one of the criteria to work is 1/4 tank of fuel minimum also outside temperature has to be below +5 (guessing now) might help you? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
2nd Dec 2024 8:01am |
No, in theory the GAP tool should over ride the temperature, particularly if all I'm asking it to do is prime.
2nd Dec 2024 10:30am |
