Home > Technical (L405) > P064F-00 Unauthorised Software/Calibration Detected
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Tinman wrote:
The rear differential replacement could be due to a faulty clutch pack issue unless it has an open differential.
My bad is wasn't a used rear diff. After further diagnosis by another shop it is found that the vehicle actually have a new transfer case instead. According to the seller there were some noise hence they replaced the transfer case. Problem is P0810-62 error is still present, I'm hoping it is calibration or wire signal causing this. If anyone else encountered this error please share your experiences. Thanks.
Post #705468 26th Nov 2024 11:54am
