Home > Technical (L405) > P064F-00 Unauthorised Software/Calibration Detected
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Moving this topic to technical, realised I posted in maintenance & mods earlier.
Hi all. New to the forum. I'm about to make payment on a 2019 SDV8 but somehow wanted to be sure so I plugged in a Launch X431pro diagnostic scanner to read the codes and found the car to have multiple errors on engine and transmission. Seller have shown recent receipts of new dpf and engine module and a used rear axle, so I am not sure if any of these are related to the error codes.
ECM (Engine Control Module)
1. P250D-37 Engine Oil Level Sensor - Circuit High. - Signal Frequency Too High
2. P250B-87 Engine Oil Level Sensor - Circuit Range/performance - Missing Message
3. P064F-00 Unauthorized Software/ Calibration Detected - No Sub
Type Information
TCCM (Transfer Case Control Module)
1. P0810-62 Clutch Position Control Error [P081 0] - Signal Compare Failure
Post #705229 23rd Nov 2024 1:57pm
Mikey
It's had either a remap or emissions system delete...
Post #705242 23rd Nov 2024 4:51pm
heretolearn
Thanks Mikey for the response. Does that mean every Range Rover that has undergone remap will show this error message in ECM? I read from somewhere it requires a bench protocol to patch and remove this error permanently. Not quite sure what it means? As my understanding Range Rovers requires bench tuning and not via OBD port. Or am I missing something?
Post #705244 23rd Nov 2024 5:02pm
Mikey
All down to the tuner Thumbs Up
I am an agent for Alive Tuning, my knowledge os limited to downloading the file from the car, emailing it away to be modified, then upload the new file back to the car
Some models are OBD, some are bench
The magic happens inside the files. A decent tuner will never cause this fault to appear Thumbs Up
Post #705252 23rd Nov 2024 5:46pm
Merchy
Not strictly 'on topic', but the info you quoted, 'used rear axle' would make me very suspicious and wary of buying this five year old RR unless there was a lot more info and good reason for this replacement
Post #705255 23rd Nov 2024 6:01pm
heretolearn
Would a 2019 SDV8 remap be done via OBD or bench? Trying to figure out what was done before this and why is could cause this kinda issues. Now that it is in this predicament, will a new tune write it off?
Post #705256 23rd Nov 2024 6:19pm
heretolearn
In the 5 years, the owner put down 66K miles and my guess it's being maintained by a not very competent shop since he couldn't provide a clear answer as to why is the TCCM showing P0810-62 code if he has already diagnosed and repaired the car. That's why I'm trying to figure out how much risk exposure I'm undertaking and what is involved in order to solve this
Post #705257 23rd Nov 2024 6:24pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The rear differential replacement could be due to a faulty clutch pack issue unless it has an open differential. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #705263 23rd Nov 2024 6:55pm
heretolearn
Tinman, how can I tell if it's open or clutch differential?
Post #705266 23rd Nov 2024 7:13pm
Mikey
Open diff doesn't have an oil temp sensor in the casing Thumbs Up
Post #705278 23rd Nov 2024 8:15pm
Tinman
Also from the infomat screen should show a padlock if it's lockable. 2017 SDV8 4.4 silicon silver AB
Post #705318 24th Nov 2024 11:44am
heretolearn
The Vogue is currently showing error P0810-62 error so what are the chances the previous mechanic fitted the wrong differential? Is there a website where I am able to generate all relevant part numbers for the transfer case and differentials via VIN?
Post #705320 24th Nov 2024 11:57am
Tinman
From what believe the Autobiography and S/C have the rear- diff lock as standard, in other models it is an option. 2017 SDV8 4.4 silicon silver AB
Post #705326 24th Nov 2024 12:56pm
Rob99
I had the same thought, the "used rear axle" on a 2019, regardless of receipts or reasons would have had me running for the exit, let alone the other issues. Shocked 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #705335 24th Nov 2024 2:21pm
heretolearn
I went ahead and bought a build sheet from vin-spec. Yeah the vehicle is equipped with locking rear differential. Now that the guess work is cleared it will be easier to work on diagnosis and repair procedures
Post #705336 24th Nov 2024 2:38pm
