![]() | Home > Technical (L405) > L405 Climate panel upgrade |
Pugster Member Since: 17 Nov 2024 Location: Hinckley Posts: 11 ![]() ![]() ![]() |
I did, looks lovely.
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
I have one I am selling if interested. It doesn’t work perfectly for the rear air vents with the 2013.
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
Hi BORA20, thanks for answering. I'm surprised the climate unit doesn't work properly as it's just a 1 plug and play. Do you think it's the unit or the year of your car 2013?? Looks like you also installed the upgraded infotainment system as well. Does that work properly and did you install t yourself?? I looked at the videos and it scared thew hell out of me. Mike |
Everything works proper except for the rear ceiling vents for some reason. I’m sure it’s a 2013 compatibility issue. The heated and cooled seats work front and rear, the front HVAC works, the screen menus work properly.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Funny you mention that Bora,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
I’m pondering that exact setup myself Ash, with the big screen and updated AC.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
if you do upgrade to this screen 'and' purchase a newer FF then you will loose the speedo dash navigation screen...
Nabbler Member Since: 11 Jul 2024 Location: South West Wales Posts: 121 ![]() ![]() ![]() |
Matt Armstrong on YouTube has got the very same upgrade including the volume controls ect on a Full fat he bought crashed and put back on the road if this helps. 2021 SVautobiography Dynamic Black ( Black wheels need to go ) 1997 C140 Mercedes Benz CL500 |
I’m not quick enough on the new cars Stan, 2nd LR one in Ludlow had already gone! Still pondering the one from the Indy in Chesterfield…… ![]() FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
Yes I did it myself (with some guidance from GaryRRs posts) - wasn't too difficult, in fact the only ticky part was getting the head unit back in with all the new wiring harness behind it - but a little patience and it was done. I didn't pay anything like £2k for mine - I posted in the other thread on the topic that they were around £750 mark for both screens. For the DSP stuff, you can still access the original OE system (its displayed on the new screen) so you retain ALL of the original features and settings - just change the DSP settings via the 'old' system - Once its up and running the press the Car symbol and you will see this...
and then
------------------------------------------------------ 2022 SDV8 AB 2016 TDV8 VSE 2011 TDV8 VSE 2006 V8 Vogue 2002 2.5 Vogue |
Ah, that looks good. So basically all the old functions and side buttons are replicated on the new screen.
Correct - thats the only reason I went for it as I wanted to keep all the original system stuff in case I wanted some of them.
Mostly listen to Ken Bruce |
