I will be watching any responses with interest as mine does something similar, although I haven't tried putting it in any other mode (never thought of it).
Mine seems to be re-learning all by itself though, albeit slowly. My indy reset the gearbox adaptions to clear a fault, which worked but left an issue whereby if you coasted a bit (eg entering a roundabout where a gap suddenly opens up) then needed 'spirited' acceleration the ecu had a fart, couldn't work out what gear to be in then slammed into engagement with an almighty thump. This all happened about 1200 miles ago, however, it's now much better and only does it occasionally and nowhere near as violently. In general all gear changes are very smooth it's just this occasional blip.
Car has 118,000 miles and gearbox recently (before the fault showed) given a flush and new (correct) oil put in. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
