Home > Maintenance & Mods (L322) > 4.2 starting problem |
RG2024 Member Since: 08 Oct 2024 Location: Warwickshire Posts: 32 |
Probably a long shot, sounds a bit silly but it's easy to check at least. Are the battery terminal clamps done up tight enough and properly seated?
20th Nov 2024 8:55am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 594 |
I needed to go out yesterday and it took 3 attempts before it would start, I had the door open so could clearly hear a click from deep in the engine bay which I assume is the starter solenoid.
22nd Nov 2024 4:52am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 921 |
Was the starter motor on mine |
22nd Nov 2024 9:53am |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 36 |
Had a similar problem on a LR Freelander a few years ago. It was the contacts on the starter solenoid. It was engaging, but no power to the starter motor.
22nd Nov 2024 1:19pm |
I actually replaced the contacts in mine with an eBay kit been good as gold since. I do prefer to repair if possible rather than just replace I figured the factory genuin must be better than a modern replacment |
22nd Nov 2024 6:09pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 |
Sounds like the starter motor. Pig of a job on the 4.2. I tried 5 times to change mine and when I did manage to remove it I ended up making and welding longer bolts for ease of any further removal. It’ll certainly confuse, and delight, any future custodian! |
22nd Nov 2024 9:26pm |
I didn't have to replace the starter motor, just the solenoid. It was very accessible on the Freelander, don't know about the L322 All the best
22nd Nov 2024 10:11pm |
Pig of a job to access on the bmw 4.4 m62 not done a 4.2 yet but doesn't look much better |
22nd Nov 2024 10:30pm |
Thanks for all the replies, not had a lot of time to sort this.
25th Nov 2024 1:30am |
