Home > Maintenance & Mods (L405) > Oil Extractor Pumps with good length pipes - recommendatios |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 140 |
I think they all have pipes that are too short for use on a Range Rover as the height up to the engine bay takes up a good portion of the pipe. Probably fine on a ‘normal’ car.
19th Nov 2024 1:27pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 197 |
Hi Alex1976, were there any specific characteristics of the rubber piping that you bought to consider?
19th Nov 2024 1:34pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1248 |
10L Draper, especially when you have oil dilution! no issue with hose length either.
19th Nov 2024 1:37pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1546 |
Good point, this post.
19th Nov 2024 1:57pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1445 |
Read this thread too.........
19th Nov 2024 2:12pm |
@Rob99:
19th Nov 2024 2:49pm |
@Gremlin500
19th Nov 2024 4:57pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Definitely 8mm on the SDV8 too. Kev
19th Nov 2024 9:28pm |
Sun's out here so just checked the tube size and it is 8mm ID that I used. Previous post edited 2021 D350 Fifty Edition - Carpathian Grey
20th Nov 2024 1:15pm |
Thanks both for confirming, so it’s the same no matter v6 or V8 Fullfats.
20th Nov 2024 1:56pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 601 |
Hi,
20th Nov 2024 9:12pm |
IRBails Member Since: 25 Jan 2016 Location: Shellharbour;NSW Posts: 9 |
I purchased a 12v Pump like this
29th Dec 2024 1:49am |
TomekW Member Since: 01 Jun 2023 Location: Warsaw Posts: 10 |
I am using Seaflo 12v gear pump
29th Dec 2024 10:29am |
I found PVC gets too soft with the hot oil and collapses almost flat, constricting the flow, whereas the nylon is much harder and resists collapse, assisting the flow.
29th Dec 2024 5:36pm |
