Home > Technical (L405) > Diesel Pre-Heater blowing cold air
rattly
Hi all,
MY L405 pre-hater is all working fine on the timer etc, but seems only to blow cold air.
Any ideas, all input welcome!!
Post #704696 18th Nov 2024 10:02am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If you mean cold air once the vehicle is running then pretty sure it's the changeover valve on the fuel burning heater. Had the same and the valve looked fine, but changed it and warm air again! I think the rubber seals swell on the valve, causing a restriction.
As yours is the V8, if you run the car to temp and check the 2 hoses going upto the EGR valve (from the drivers side of the engine bay) in the centre of the V, if one is hot and one cold (or cooler than the other) then that's definitely your problem. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704697 18th Nov 2024 10:19am
rattly
Hi,
Thanks for the reply,
My normal heater is working fine once up to temperature.,
Its the pre-heater, it kicks in on the remote, and you can hear the burner running, but its only blowing cold air at the screen.
Post #704700 18th Nov 2024 10:55am
4RRS
Got you!
The valve diverts hot water to either the block or the heater matrix, but as your normal heating works fine I'd say it rules out the valve (unless anyone knows better?). There is a coolant pump that runs in tandem with the Fuel burning heater, located just to the left of the unit, maybe this isn't running, thus not allowing the coolant to circulate to the matrix. I seem to recall the pump starts just before the FBH, so maybe start it from timed or the remote and see if you can hear the pump before the FBH cuts in. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704703 18th Nov 2024 11:24am
rattly
Thanks for this...
I have actually changed the diverter valve (LR167749) recently as wasn`t getting any heat in the car, now all working.
I bought this one earlier this year so was unaware of heating faults etc..
Its really cold here tonight so will see what happens in the morning!
Post #704827 19th Nov 2024 3:07pm
E500
It takes ages for it to actually warm up. I turned mine on this morning and 20mins later I could see it starting to defrost / melt the snow on the windscreen. By the time I got into the car ~25mins after turning it on, it was toasty. But it doesn't do much for the first 10mins or so, in my experience.
If it's still cold after 20-30mins, you've got a problem!
Post #704828 19th Nov 2024 3:12pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Just to add, I thought the heater initially heats the water and that circulates round the engine to heat that.. only when that water is up to temp (whatever that is) it diverts the warm air to the cabin.
Its main function is to heat the engine I thought..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #705159 22nd Nov 2024 5:35pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
It's kind of the other way around. Normally during pre heat the heater coolant circuit is isolated (by the changeover valve) from the engine coolant circuit, so that only the heater circuit is heated by the fuel burning heater.
However, if the temperature is less than -20 degrees C then the changeover valve will remain open, so that the engine is also warmed, to aid starting, and the heater blower won't start until the coolant is "above a suitable threshold".
Post #706656 12th Dec 2024 12:26am
