Home > Technical (L322) > Adaptive front suspension fault 2010 3.6 TDV8
klf400
Have this fault at the moment
Tested continuity on the 2 wires that plug into the suspension strut and it’s all good,
The wiring from the plug goes backwards into the main loom and there is a factory joint just before it goes into the main loom this is where I back probed the loom to the plug and I have continuity, but I still have the fault.
Any ideas? Maybe the strut itself? 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704567 16th Nov 2024 12:09pm
kevinp
The wires usually break near the top of the strut. They go fragile and break with the strut turning side to side.
Post #704573 16th Nov 2024 2:49pm
klf400
I’ll double check them but they seemed good when I checked them and ran a continuity test 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704587 16th Nov 2024 6:58pm
mjdronfield
Have you got a fault on the dash?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #704589 16th Nov 2024 7:16pm
kevinp
Try peeling the top 4" of loom tape off and look at the wires.
My insulation was broken in a few places and the wires snapped. Perhaps when you are doing the continuity test you are folding the wires back into contact with each other.
Repaired mine twice which broke again so I then got a repair kit. Thumbs Up
Post #704591 16th Nov 2024 8:11pm
klf400
Yes adaptive dynamics fault 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704599 16th Nov 2024 10:20pm
klf400
I’ll double check this again tomorrow and post my findings 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704600 16th Nov 2024 10:21pm
mjdronfield
Yes, as above, one of the wires has broken on the cables to the fronts. It could be rear but very rarely as the front ones have to turn with the steering. Recommend getting a couple of repair kits and doing both.
Ride made me feel sick on a dual carriageway when mine did that 😱🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #704637 17th Nov 2024 1:18pm
JayGee
You should be able to test the damper internals for a short or open circuit by using a multimeter across the pins and checking resistance and compare it to the other side. Never heard of the internals failing electricaly but as others have found the wiring is a frequent point of failure. If you have a look at any wiring and connectors on these cars it's obvious a cost saving excercise was done as bare insulators are exposed before virtualy every plug and socket even in criticaly exposed areas under the car Censored Censored Censored 2012 TDV8 Vogue (L322)
Post #704640 17th Nov 2024 1:38pm
klf400
Well guys thank you for your input I have inspected the wiring again and gave it a good flexing to try and find a break but nothing , however after putting it back together it’s now ok and working with no fault, I am expecting it to come back but maybe just replace the 2 front looms to be sure, comparing them to my 4.4 TDV8 they have been replaced before where the 4.4 hasn’t.
Coming back to the original problem that’s gone I now have this
I’ll take a look first and check the wires and multi plug although it appears to be working as the suspension goes up and down no problem 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704676 17th Nov 2024 10:41pm
