Home > Maintenance & Mods (L405) > Scuttle panel clips
MattEngineer
Scuttle panel clips
I put my 2017 autobiography through the multi point check and one of the things that came up were 4 missing scuttle panel clips. I picked up some off Amazon, they’re 9mm thick and look identical to the rest of the clips in the engine bay but they don’t fit the scuttle panel.
The lower section the scuttle clips with looks threaded, I would welcome thoughts or pictures, are the part numbers different?
One option would be to drill out the plastic lower scuttle panel which I’m a little reluctant to do given it’s doesn’t feel like the right solution.
Thanks all for the help and collective wisdom.
[/i]
Post #704257 11th Nov 2024 8:21pm
Just buy new ones from the dealer, send a picture via email to Duckworths our site sponsor and they will get you some, just did a load of mine, mention the forum for some discount....
Since Sophie took over you may have to chase it up a bit...!!!
sophie.alltoft@duckworth.co.uk Pete
Post #704290 12th Nov 2024 8:06am
Green Machine
United Kingdom 2014 Range Rover Autobiography SDV8 Aintree Green
scuttle panel clips
I removed my scuttle panel this week for an oil cooler job and the 4 clips on the scuttle panel are thinner with a star head screw instead of the the flat top with a cross type for all the rest of the engine panels.
https://vehicleclips.co.uk/collections/lan...hLYM-McYT8
if you use that link it shows a 6.5mm screw rivet and that should work.
Hope that helps.
Post #704609 17th Nov 2024 12:12am
