Home > Technical (L322) > Restricted Performance
Herald
England 2012 Range Rover Westminster TDV8 Santorini Black
Today we’re cruising up the motorway in our 4.4TDV8 and restricted performance comes on. We reached our destination slowly and plugged in IID and discovered code U3003-17 Battery Voltage general electrical failure circuit voltage above threshold and then 90 minutes later U3003-16 voltage below threshold. Cleared the faults and all good so far. Any thoughts please on this? Searched the codes but can’t see any threads already.
Post #704150 9th Nov 2024 6:06pm
JayGee
I’d strongly suspect the alternator if the voltages are swinging outside the normal range. 2012 TDV8 Vogue (L322)
Post #704152 9th Nov 2024 6:29pm
Herald
Thanks, I hope not, it’s only about 4 years old! I do agree though that it looks suspicious!
Post #704156 9th Nov 2024 7:19pm
