Home > General (L405) > Cost to get a new key ?
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Hi,
Has anyone recently bought a new key from a dealer and if so, how much did they charge ?
it is for a 2021 car.
The dealer I spoke to was saying that with the revised security you can't simply get a key and program it, the whole system needs recoding.
Cheers
Richard 2016 AB SDV8 Barolo black
Post #703868 6th Nov 2024 11:00am
garyRR
A good locksmith will take the module out, read it with their programmer and can create you another key. It'll be £200-250 for that kind of job.
Contact Hertfordshire Car Keys. They'll be able to sort you out. 2015 Range Rover Autobiography 4.4 SDV8
Post #704006 7th Nov 2024 9:33pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I believe you can programme a key yourself with an IID tool.
The keys themselves can be found on Amazon for about £20, which include the case, the electronics and a blank key. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #704072 8th Nov 2024 5:54pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
yes i can confirm that the gap tool will program a key even when from a different range rover (done two) takes about 2-3 min
Post #704094 8th Nov 2024 8:29pm
maxbasscat
England 2016 Range Rover Autobiography SDV8 Carpathian Grey
I have searched for this outfit and little comes up. Have you more information that you can share?
Post #704100 8th Nov 2024 10:04pm
garyRR
https://www.facebook.com/londonautolocksmiths 2015 Range Rover Autobiography 4.4 SDV8
Post #704105 8th Nov 2024 11:05pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
I can only report from the German area: If you want a new key for the Range Rover from 2015 onwards, the control unit has to be reprogrammed and not even the clever car thieves from Lithuania can do that so easily, even my long-time key supplier couldn't do it. The key itself may only cost 50 euros with a transponder, but it's of no use. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #705264 23rd Nov 2024 7:56pm
maxbasscat
Thanks I will investigate and report back
Post #705367 24th Nov 2024 9:44pm
supershuttle
I got an unprogrammed Key from Dan at Duckworhs (he's no longer there) for £70 and programmed it with an idtool. Geoff
Post #705368 24th Nov 2024 9:59pm
