![]() | Home > My Range Rover > My 2012 Westminster TDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 830 ![]() ![]() ![]() |
do you mean the Invery Bluetooth adapter ?
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 ![]() ![]() |
Front disks sorted today. After a quick test drive, the soft test grumbly feel has gone and the brakes now feel firmer and more confidence inspiring.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 ![]() ![]() ![]() |
Good luck, hope itβs not too bad under the sill plastics. Bottom of the rear arches tends to be the nightmare bit, all repairable but a bit of a faff.
So far so good, the worst bit by far has been the metal that holds on the lower panel under the front side vents
All sorted. I used Nutrarust to treat the rust then Lanoguard to seal everything from front to back from the coming winter. The rear arches weren't too bad but not good for a 12 year old car. More worrying was the mount as per my earlier post. Both were bad but now sorted. If you've not checked yours, pull of the trims and check them!
When fittind the old trim protector and the new ones (the Freelander part that is cut to size), I covered the arch area, inside and out, in the Lanoguard grease as well as packing some in the trim strip too. Similarly with the lower trim mount, it was covered in the Lanoguard grease on the inside before mounting and then the outside once it was on the car. Hopefully everything is now ready for the winter!
Morning,
Yes, that's the after pic. The sill covers came off, the foam insert out, arch liners off etc. Nutrarust on the rust, once dry then Lanoguard everywhere including in the sills |
Top job! Lanoguard will be sponsoring you soon π |
My inspiration was from Sam's Motors and Machines, much more effective use of sponsorship than me π |
Went to the gym today and saw a twin in the car park
I created a better mount for my Android screen. 1.5mm aluminium plate, bent into shape with a vice and a 3/8 extension bar to created the curve. The screen is mounted on using high strength velcro. Super simple and very effective.
Looking very tidy, well done.
Fresh boots for the fattie today. Continental 3 Peak all seasons on each corner, 255/55/R20 so slightly up from the 255/50s. If the speedo is out I'll adjust it with the Gap tool.
