Home > General (L405) > New Owner what OBD software can I get?
Starbuck88
2014 Range Rover Vogue SE SDV8 Loire Blue
Hi All,
I have bought an L405 Vogue SE SDV8 and coming from mainly running BMWs for ages I don’t have any kit to diagnose it.
For BMW I had a hooky copy of ISTA the software BMW use.
Is there a go to kit that comes with software and cable for Land Rover?
I’m seeing IID, Gap, SDD and don’t know where to start.
Kindest regards
Post #703453 30th Oct 2024 7:27pm
the GAP iidtool is very highly regarded on the forum.... ... - .- -.
Post #703454 30th Oct 2024 8:26pm
DrRob
GAP IID. No brainer Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #703457 30th Oct 2024 9:12pm
DaveBL405
United Kingdom 2019 Range Rover Autobiography SDV6 Balmoral Blue
GAP IID are super expensive - £450+
I could understand if an owner was going to get their hands dirty and do their own servicing etc, but for the average owner who would still take it to a main dealer or LR specialist anyway for servicing and issue resolution is there a use case that warrants that kind of outlay?
Post #703571 1st Nov 2024 4:09pm
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Suppose it depends on how much you want to access and set or reset.
For my purposes I have the Veepeak OBD11 Bluetooth reader. Splendid little device that shows live data and any fault codes with a link to the web attached to any code for research. Clearing codes is included and there is a ‘pro’ upgrade for a nominal subscription or one off payment. Otherwise, you just download the app to your mobile or iPad/ laptop and away you go. I’ve had this a couple of years and use it on my recently purchased L405 AB, my Bentley GTC and the wife’s Mini Clubman Cooper SD. Works great and purchased from Amazon , £33.
Pic below.
Post #703575 1st Nov 2024 5:57pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
elm is ok just for general powertrain codes. You miss 90% of ECUs
Post #703576 1st Nov 2024 6:28pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Autel Cheers
James
Post #703588 1st Nov 2024 10:13pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
For me GAP Diagnostic IID is a no-brainer some justification:
£450 is around 4 main stealer visits, as they charge c. £100+VAT for the first "diagnostic" hour, warranty or not.
If you get rid of the Range, or buy a newer one, re-homing the tool to a new VIN is cheap, and the resale value is excellent.
The tool set allows you to perform a LOT of functions over Carly et al. I've just swapped the transfer box oil in my SVA and reset the clutch adaptations, The issue at a dealer calls for a double flush. I will change the 1.5l of fluid again next week and reset again. Fluid was c. £69 for 3l, not sure the 2024 cost of a dealer/specialist doing that, but it's more.
Programming/changing the Car Configuration File is included and easy.
Even going for a 4 wheel alignment means (to have it work properly) putting the suspension in "tight tolerance" mode, the IID can do this.
Options for SW upgrades and even remapping exist within the eco system.
The live values and app are superb on either tablet or phone. The latest G4 model connects over IP and is even faster.
Above all of the above, ANY time I have contacted the team at GAP, they've been incredible with support. Even possible to get Beta/one-off SW builds to satisfy a more bespoke function.
I can't recommend them highly enough.
I know this may sounds like a sales pitch, but I don't have any affiliation, I just work as an Engineer and appreciate what the team at GAP have achieved for a reasonably low price.
I hope this is some use, if not- apologies for going on so long! Formerly happymadison1978
Post #703592 2nd Nov 2024 12:51am
maz
Scotland 2011 Range Rover Vogue TDV8 Bonatti Grey
Whatever you do, dont buy the Nanocom update for the L322, its practically useless. I already have the unit for managing my TD5 Defender and thought I could get the Gap functionality for the £200 upgrade but I was wrong, it can read ecu and clear ecu and 1 or 2 other things and thats it. Bit of a farce for them to charge for it. Had to go through a Paypal claim to get my money back as well due to their method of supplying licenses. I will pay the extra for a Gap tool now. 2011 4.4 TDV8 Vogue Grey/Ivory
Post #703601 2nd Nov 2024 12:08pm
Gremlin500
#4 for the GAP iiD BT G3 (or G4 for post MY17).
Second-hand G3’s come up on here & elsewhere for about £300 (but you have to be very quick!)
These units hold their value amazingly, as others have said, especially when purchased used.
However, I have also used the excellent iCarSoft LRV3 which is much more intuitive with its own display, and TBH it now does everything the iiD tool does except for editing the CCF, (which not all users want to fiddle with, only the diehard tinkerers Embarassed ). At £175 for the usual stuff like scanning for DTC’s, battery swap, various service resets etc. it’s hard to beat, there are lifetime updates and service support also, although the latter can be a bit slow at times.
Horses for courses, much depends on what you want to do with it, as much as on the tool itself, but it’s good to have so many choices, don’t rule anything out initially, and do a bit of learning before you buy. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #703604 2nd Nov 2024 1:23pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Gap all the way 👍👍
Support service is second to none 👌 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #703612 2nd Nov 2024 6:08pm
As above, GAP IID all the way Thumbs Up
Post #703635 2nd Nov 2024 10:36pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
wouldn't be with my gap tool cant beat it and the support from them is fantastic Thumbs Up Thumbs Up
Post #703725 4th Nov 2024 1:19pm
