Home > Technical (L322) > 2011 front parking sensor removal 4.4 AB |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 314 |
Might depend on how it’s been pushed in. If it’s only the round centre part then it should simply push back into the “holder” if you can get to it from behind. If however the holder has been pushed in then you may need to get it off do effect a proper repair.
28th Oct 2024 7:51pm |
This is the bit that causes a bit of trouble if it’s been pushed in;
28th Oct 2024 7:55pm |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 28 |
Hi Scouse, that's the earlier version with the bezel. Mine is almost flush fit with no surround trim. If i have time tomorrow, I'll take the wheel arch liner off and take a look inside. Thanks for your reply. |
28th Oct 2024 9:08pm |
Ok well if it’s without the oval bezel then it will be similar to this below, I just did a Mercedes rear bumper for a friend and the plastic retainers get pushed off the back as they are just held by a heat process from the factory and if separated need glueing back.
29th Oct 2024 9:20am |
Excellent, thanks. I'll see how I go. Just waiting for the weather to improve. Thanks again. |
29th Oct 2024 12:30pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 863 |
I’m 99% sure to access any of the parking sensors, the bumper has to come off, as the bumper crash bar behind inhibits access to them even with the wheel arch splash guard removed.
29th Oct 2024 1:48pm |
I think you are correct JCW, they are recessed into holes on the crash bar.
29th Oct 2024 2:13pm |
By the way if you have not seen it this should be helpful:
30th Oct 2024 11:55am |
Hi all, just to confirm, this is now resolved. Thanks for your advice. It was a simple fix, wheel arch liner partly removed and I could just gain access to the park sensor. It had actually broken the moulding away from the bumper cover inside so some eposxy resin and heat gun resolved that. Sensor fitted and working.
30th Oct 2024 2:56pm |
Well done that man.
30th Oct 2024 3:31pm |
