Home > Technical (L460) > Battery Issues - Any Ideas? |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
Mine’s a D350 with the mild-hybrid 48v battery as well as a normal 12v battery. I can leave it for 2 months without any sort of charging and it starts first time. The first ever RR that I’ve owned that didn’t discharge after a couple of weeks or sooner.
22nd Oct 2024 5:35pm |
martincfreeman Member Since: 15 Mar 2011 Location: Flatlands of Lincolnshire (but the Kerbs are pretty high!) Posts: 30 |
That’s a good point, I cannot remember seeing the message saying that the “telematics” have shut down. Will keep an eye out. |
22nd Oct 2024 6:39pm |
So after 4 days, I am still able to see the information from the car (and getting the confirmation "updated just now"
25th Oct 2024 11:08am |
Mine’s been rested for 36hrs now and according to the App isn’t in sleep mode yet. MY23 D350 HSE
25th Oct 2024 11:33am |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1242 |
I had this issue. Long story you can find on another post. Nov/dec 2022. Long and short jump started by the rescue squad . Taken to the ( very rude) dealer a few days later, could find nothing wrong. They did charge overnight, I’m not sure if they have a bigger better chargers that teach parts the alternator is unable to reach.
28th Oct 2024 12:01pm |
I have a slot at a dealer in November so will see what happens between now and then. I used the car over the weekend (40 + 40 miles) and it now isn’t going to get used for a couple of weeks. Will see if it goes to sleep (or goes flat). |
28th Oct 2024 8:41pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1555 |
@Martin:
28th Oct 2024 10:15pm |
Thanks @Gremlin500, ironically I do have one of the Ctek Li-On chargers and was going to put it on charge the day it last ran flat (typical). The problem is that there are so many processors and supporting electronics on these cars that gone are the days of using a switch to operate the window motor….. now a switch tells a processor to put a “window down” message on a computer network which is confirmed by the body control unit and then it sends a message down another computer network to another processor that switches the motor on…. Just crazy. My guess is that one of the many processors is not shutting down under certain conditions and hence killing the battery. I figure it will eventually be found. As I don’t have any other theories at the moment, I am blaming the county of Norfolk in the UK as it seems to nearly always happen within a few days of me leaving the county….😂😂 |
28th Oct 2024 11:22pm |
