Home > Technical (L322) > Dropping out of first gear when cold? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Was it happening before you had the fluids changed? |
21st Oct 2024 3:41pm |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 34 |
Not sure to be honest, I'm just really starting to listen for things if you know what I mean, I haven't driven it a lot yet. Lets assume it was....
21st Oct 2024 3:51pm |
First check I would do is make sure oil level is correct in gbox.
21st Oct 2024 4:28pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
When the fluid is cold its high viscosity means it takes longer to return to the sump and, if the fluid level is low, the suction port in the filter may become uncovered allowing the pump to suck air momentarily. As dingg1 has already suggested, I would definitely check the fluid level first.
21st Oct 2024 6:04pm |
Thanks for the replies.
21st Oct 2024 6:37pm |
