Home > Maintenance & Mods (L322) > Seized pins in callipers extra six hours labour |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th Dec 2017 4:18pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
I can see how that might work from the outside with the pin intact but the problem I found was that the pin gets stuck at the other end where the clip is on the pin. In my case the other end stayed fast and the pin just bent. I then had no choice other than to cut the pin leaving a stub to press on. I ground a chamfer on the inside cut end so it wouldn't get stuck when pressing it out.
19th Dec 2017 7:52pm |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Hi Craig
19th Dec 2017 8:57pm |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 22 |
Just had the joy of doing the front brakes on my 2012 4.4 TDV8 with the Brembos. Those pins are a nightmare.
20th Oct 2024 12:20pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1551 |
Prevention is better than cure!
20th Oct 2024 12:45pm |
