![]() | Home > General > Leaving the RR for a month |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I leave mine on the CTEK without issue. That’s what I’d do.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
I've got a cheap generic trickle charger and the 405 has lived on it for three months with no issues, in fact it's on it now as we are off for a couple of months tomorrow...
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Thanks gents. So trickle charge (I use the lighter socket in the boot and feed the extension lead between upper and lower tailgate and lock it with the remote? |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Disconnecting the battery is a simple fix but not sure what you mean about using the lighter socket - do you mean to provide power to the charger, if so that’s not going to work.
Scouse, sorry I meant plug the CTEK into the lighter socket in the boot like I usually do, then run extension lead it’s plugged into from the house, between the upper and lower tailgate.
