![]() | Home > Maintenance & Mods (L322) > Drivers Seat Fault |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 41 ![]() ![]() ![]() |
I have a fault on the drivers seat on my 2006 TD6. The drivers seat adjustment and memory switch only partly work, the seat will move forwards but not backwards, the large button to recline the seat does not work but the small one does, the memory position 1 does not work
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Yellow plugs are airbag plugs and you should turn the ignition off and leave the car for some time before playing, can't see they will be your issue though.... Pete
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 34 ![]() ![]() ![]() |
Its not a yellow 'plug' its a 36 plus way double row connector with a yellow shroud - on 2002 to 2006 model I'm not aware of an airbag fitted to the drivers' seat but I'm happy to be corrected for safety concerns Current: 2003 TD6 HSE. 161,000 miles
You said yellow connector in the first post, if it's just the shroud then that should be fine... |
