Home > Wheels & Tyres > My nuts are swollen
RobsterPC
My nuts are swollen
At least on the L322 they are. Having read that it's a common issue on here I've duly checked my new-to-me Westminster and all of them are no longer 22mm. Any tips for removing them? I don't want to happen a 22mm socket on then find out I can't get it off. As simple as using a 23mm? A full set of replacements are on order...
Post #702583 19th Oct 2024 12:52pm
fisha
23 will probably work fine. just wait till you get the new ones delivered. V8 or else ...
Post #702584 19th Oct 2024 1:43pm
Scouse Exile
I’ve now changed all mine but I would recommend keeping one of these in the car as it just might save you being stuck at a roadside;
https://amzn.eu/d/bdOyMKd
Worked great on my swollen nuts 😁
Jon
Post #702589 19th Oct 2024 2:13pm
RobsterPC
I've ordered a 22.5mm socket from Amazon too. Its looking like next weekend is going to be a busy on on the FFRR for me. Fix this, new front brakes, clean, rust rust and protect underneath and then finally get to drive it!
Post #702590 19th Oct 2024 2:14pm
mjdronfield
I’ve got rid of all my locking wheel nuts too, they did the same. Stainless new ones are the best as won’t rust, but they are expensive.
Just replace them with a set off eBay and check every 8 months or so. If starting to swell, swap out.
Bit of a pain….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #702598 19th Oct 2024 2:56pm
DrRob
Replace all with new AllMakes ones from Advanced Factors. They are OEM.
Avoid the cheap Censored on eBay. Ditch the locking ones.
https://www.advancedfactors.co.uk/rrd50029...4909-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #702619 19th Oct 2024 6:17pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I use an imperial 25/36 for my swollen nuts….
Post #702668 20th Oct 2024 11:37am
