Home > General > Seat Foibles
lex
Australia 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Seat Foibles
Whenever i drive my FFRR after my wife has driven it with her particular seat adjustments ;the car always reverts back to these settings when i next start up. Trying to crush me against the steering wheel. Is there a secret widow setting that Land Rover sends to the wives or am i missing somthing in my setup? We each have our own key.
Regards
Lex Franks
Post #70256 28th Jun 2011 1:21am
IIRC there is a way to set each key to a drivers desired seating preferences , it's on here somewhere as there was a thread about it .
I could be wrong but put key 1 in the ignition at position 1 set the seat to your personal choice press M at the side of the seat and this i think will store the settings to key 1.
Then do the same with key 2
Post #70257 28th Jun 2011 2:40am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
As far as I know the vehicle will revert to whatever seat setting was last used with that key - have you tried asking your wife to push your seat setting memory button once she has exited the vehicle and before closing the door?
Post #70258 28th Jun 2011 4:53am
Works on both my keys separate settings .. Thumbs Up
Post #70259 28th Jun 2011 5:13am
as said above, each key 'can' have its own settings..in the manual i believe..
Post #70262 28th Jun 2011 6:39am
pretlove
this is what i thought to be true as if i pick up the wifes key by mistake i also get crushed where as my key is fine.......im sure it just remembers the last position that key had the seat in "RANGEISM WILL NOT BE TOLERATED"
Post #70335 28th Jun 2011 12:46pm
