Home > Maintenance & Mods (L322) > Cracked inlet manifold |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 29 |
Before you ask, I resorted to removing the ABS pump to give more room and then cutting out a 1" square from the chassis rail. I will weld that piece back in afterwards so that nobody will actually know - apart from you of course. |
11th Oct 2024 4:59pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 789 |
Lifting the engine with a jack a few degrees on each side gives enough room to remove the back injectors
13th Oct 2024 12:58am |
Like others before me, I have failed to find the bolt at the top of the engine mount on the right hand side. The left was easy, but I could neither see nor feel the bolt on the right. Even with the plastic moulding behind the suspension strut removed and an opening revealed to the side of the engine, I still could not solve the problem. As some seem to have been able to access this bolt, I am beginning to think that not all 3.6L TDV8 engines are the same. |
13th Oct 2024 9:32am |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 72 |
For the OSF engine mount I did have to resort to a bit of ‘metal work’
14th Oct 2024 1:20pm |
A close up you say….?!
14th Oct 2024 1:22pm |
Giving the inner wing seam a bit of a pummelling and you will be able to get a spanner on it. 2007 Range Rover Vogue 3.6 TDV8 |
14th Oct 2024 1:23pm |
I've just seen the bolt for the first time - through the tiny gap between the engine subframe and the chassis rail. On another forum, I've seen somebody using a home-made crows foot with about a 3" offset. On balance, I think my approach with the angle grinder, taking a 1" square out of the chassis rail is the neatest and quickest approach. I did have to take out the ABS pump to make room for the angle grinder, but I think I would have taken it out anyway, just to get better access to the injectors.
15th Oct 2024 11:26pm |
