![]() | Home > Maintenance & Mods (L322) > Cracked inlet manifold |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Before you ask, I resorted to removing the ABS pump to give more room and then cutting out a 1" square from the chassis rail. I will weld that piece back in afterwards so that nobody will actually know - apart from you of course. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Lifting the engine with a jack a few degrees on each side gives enough room to remove the back injectors
Like others before me, I have failed to find the bolt at the top of the engine mount on the right hand side. The left was easy, but I could neither see nor feel the bolt on the right. Even with the plastic moulding behind the suspension strut removed and an opening revealed to the side of the engine, I still could not solve the problem. As some seem to have been able to access this bolt, I am beginning to think that not all 3.6L TDV8 engines are the same. |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 90 ![]() ![]() |
For the OSF engine mount I did have to resort to a bit of ‘metal work’
A close up you say….?!
Giving the inner wing seam a bit of a pummelling and you will be able to get a spanner on it. 2007 Range Rover Vogue 3.6 TDV8 |
I've just seen the bolt for the first time - through the tiny gap between the engine subframe and the chassis rail. On another forum, I've seen somebody using a home-made crows foot with about a 3" offset. On balance, I think my approach with the angle grinder, taking a 1" square out of the chassis rail is the neatest and quickest approach. I did have to take out the ABS pump to make room for the angle grinder, but I think I would have taken it out anyway, just to get better access to the injectors.
The independent who I use mentioned to me that the pressure that builds can really make them bulge! You might not even spot the split - high pressure smoke test might help reveal more?
Looking at the rigidity of the plastic mouldings, I really can't see them bulging with pressures as low as those from a standard turbo. If there is a weakness, it is likely to be where the separate moulded parts are bonded together. As you say, a high-pressure smoke test would confirm, but the chap who did the diagnostics seemed absolutely certain.
If yours is a 3.6 then there is absolutly no problem with blanking the egrs, no errors will show. You can then get them mapped out if you wish but not necessary. The 4.4 is a different kettle of fish 2007 TDV8 VSE
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
My L322 inlet donut split on the inner rear seam - couldn’t see the split with the engine off, but there was obvious soot above it on the underside of the engine cover. I’ve seen pictures of one (on here?) with a load of self-tappers around the inner seam. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 70 ![]() ![]() ![]() |
My LH manifold split in front of the front donut connector hose. No visible gap, just a light misting of oil. |
