![]() | Home > Maintenance & Mods (L322) > changing the wheels |
Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 44 ![]() ![]() |
That's fantastic! I'd definitely be interested if you are making a few of these |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 607 ![]() ![]() ![]() |
I got mine from Powerfuluk, plenty on eBay as well Range Rover 4.2 Supercharged 2006
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Miggit who was on here a few years ago made some for those that wanted them.
If anyone is interested in making any.
M14 x1.5mm pitch not 1.75 which is on most general purpose bolts of this size. When I jack mine up I just do it enough to clear the tyre off the ground so they just push back on without much lifting but if you are needing more access height one of these would be great. I'd say you could probably get away without threading the end and just have a 14mm hole to speed up the process. 2012 TDV8 Vogue (L322) |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 791 ![]() ![]() ![]() |
and i thought i had a good idea, but its all been done before, hawell RR 2005 4.4 petrol
what do they call these, i would like to look it up on ebay, just to see how they have made them
Do a search for "Alloy wheel Alignment fitting tool" 2012 TDV8 Vogue (L322) |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
@nicedayforit - Cheers for the drawing |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
I lost my set temporarily when I moved house and got a stark reminder of what a difference they make to wheel changing, but thankfully I found them again in the safe place I had stored them in so very happy again |
Thanks for all the tips! I'll will employ my google skills as opposed to machining skills |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 177 ![]() ![]() ![]() |
Come in handy on a super tanker I expect Merchy |
Spot the alignment tool....
i see on a demo, they use two alinement tools and they are not tapered
