Home > Maintenance & Mods (L322) > Servicing questions - L322 4.4 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
you could use the forum search function... ... - .- -.
11th Oct 2024 7:40pm |
thomas88 Member Since: 23 Nov 2023 Location: Harrogate Posts: 13 |
Didn’t think of that… thanks for your input |
11th Oct 2024 7:44pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 393 |
Hi Thomas,
11th Oct 2024 7:58pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If you go to the WIKI section there are 2 downloadbale service PDF's which give the intervals for various fluids and check this against any service history you have. If you are a new owner I would strongly recomend taking it to a good LR indy and getting them to do a full inspection report as you need to prioritaise any critical maintenance over servicing and know exactly what you are 'in for'. Most service items are not critical or detrimental if over extended a bit but engine oil needs more regular changing than the official intervals as now these cars are quite old the DPF's are needing more regeneration cycles which creates oil dilution issues so most here are changing at 5-7k miles. Thankfully it's a realy easy and cheap job with an oil extractor and suitable C1 oils from Opie and Smith & Allen. 2012 TDV8 Vogue (L322) |
12th Oct 2024 8:23am |
