![]() | Home > Technical (L405) > TPMS Problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
i suspect the replacement tpms were not activated [switched on] ...there is a tool that will do this ... ... - .- -.
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 245 ![]() ![]() ![]() |
There are also two different frequency TPMS. Aftermarket units are typically dual frequency. I suspect like Stan said they weren’t activated and/or updated with the car. I have the $400 🇨🇦 tool to do this at home. Takes less than five minutes to activate and connect them to the car through the OBDII port. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
Looping111 Member Since: 28 Jan 2024 Location: Zuckenriet Posts: 14 ![]() ![]() ![]() |
The sensors where cloned with the ID of the old ones and all where programmed to the system. The programming unit reports that all was successfull. It was possible to read them out with the tester. When I disconnect the battery 10 min. after restart the car the error was cleared and I could view all tyre pressures in the service menu. So I understand that the sensors are activated and work. But after 20min. the error comes again....therfore I am not shure if the control unit itself is the problem ?? |
Today I checked the voltage of the battery, but in the front at the plugs for remote start. Only 11.6V, but there is maybe a drain .. So this evening I will check direct at the batteries under the spere...
